January 3, 2006, 01:22 |
Max time step for semi-implicit mtd
hello,
I've coded a 2d structured FVM fractional step NS solver. It's fully implicit (using CN2). It worked fine. Now I've modified it to be semi implicit (using CN2 for diffusive, AB2 for convective). I know max CFL <=1 for semi-implicit mtd. In the mtd I've used, it was given CFL = max(|u(i)|(delta_t/delta_x(i)) ~ 1. However, it was given for cartesian grids. I've tried to use replace delta_x(i) with the quadrilateral's edge length. The prob is for very small time step (CFL<<1), both give pretty similar results. However, for reasonable time step (CFL~1) and long duration, errors start appearing for the semi-implicit mtd. Btw, I'm simulating flow past an airfoil at 0deg AOA at Re=10. So is this an inherent limitation of the semi-implicit mtd or it's due to my own errors? Thanks |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
Doubt on Implicit Methods | analyse In India | Main CFD Forum | 10 | March 9, 2007 03:01 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
