Modelling Heat transfer
Old   August 23, 2012, 09:11
Default Modelling Heat transfer
Lancashire
khuram87 is on a distinguished road
Hi all...
I am trying to simulate a flow in a ribbed channel
periodic boundary conditions are to be used
i have tried various meshing techniques including the size functions etc but still I am getting very high heat transfer values compared to experiments.
i am using k-eps standard EWT, with energy equation (k-w model apparently doesnt give desired velocity profiles)
if I make the cells too close to the wall, I get an error in fluent that "Aspect ratio is very high for some cells and the default code might not work".
The link to the problem description is (https://www.dropbox.com/sh/4u2y106krwo9knj/X7DaKglhp_)
Please reply ASAP
khuram87 is offline   Reply With Quote
fluent, heat transfer, meshing
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 07:45
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Modelling Heat transfer between stack and gas in Thermoacoustic Chirag2302 FLUENT 0 April 24, 2012 01:14
Modelling combustion and heat transfer Tudor FLUENT 4 May 9, 2005 07:02
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 05:09
