Cell vertex V.S Cell centered for FVM
Old   August 17, 2012, 16:29
Question Cell vertex V.S Cell centered for FVM
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
Hi
Could you please briefly summarize comparison between cell vertex and cell centered?
I tried to look for the answer online but failed. Thanks!
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   August 17, 2012, 21:01
leflix is on a distinguished road
Originally Posted by Anna Tian View Post
Hi
Hi Anna,
First you have to undertstand how we derive them.
Let's assume you know....
Each of these two approaches has advantages and drawbacks. Generally the advantage of one is the drawback of the other.
For example for cell vertex (or node centered) approach in case of non regular grids
the faces of a control volume are always half way between two nodes. It's not the case for cell centered. The consequence of that is the first derivative phi_e=(phi_E-phi_P)/d(P,E) where d(P,E) is the distance between node P and E is necessarly second order For cell centred approach the same discretization of the first derivative will be first order only.
In case of non regular grids the interpolation factor will be 0.5 and interpolation at face center will then be easier. It won't be the case for cell centred and interpolations will be more cumbersome to perform.
For cell vertex, grid points fall on the boundaries and the distance between a boundary node and the next interior node remains the same than for all interior nodes. It is easier for boundary conditions treatments.
The only drawback that I see for cell vertex approach is that for very skewed grids the node P may be outside from its control volume. In cell centred approach this pathologic situation can never happen...
However even if cell vertex seems to present some advantages over cell centred approach the latter is more widely used but it is really a question of choice.
leflix is offline   Reply With Quote
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
