How to validate heat transfer modelling?
Old   January 10, 2006, 01:16
Default How to validate heat transfer modelling?
poornima
I modelled two dimensional heat conduction in a cylindrical wall with convective boundary conditions. I want to validate the results.
Can anyone suggest how to validate the results. Are there any standard problems available for this?
Old   January 11, 2006, 02:42
Default Re: How to validate heat transfer modelling?
ztdep
set the heat transfer coefficient to a very large number, so it will become a simple problem which has analical solution.
Old   January 11, 2006, 03:02
Hubert Janocha
In many many litrature or scripts from your university there are equations for this problem. So you would get analytiv solutions for simple geometry problems.
Old   January 12, 2006, 09:09
poornima
I am not looking for analytical solution, i am looking for numerical solution. i have solved one problem but i want to know that this method is reliable, stable, and can be generalized. is there any standard problem with resutls which i can solve to verify that my program works.
Old   January 12, 2006, 11:49
Jim_Park
What ztdep and Hubert Janocha might be suggesting is the following:
A numerical solution that you get will surely come from someone else's code (guess that's obvious!), AND that code was very likely validated against analytic solutions. So why not cut out the middle man and generate your own analytic solution? I just opened Chapman's "Heat Transmission", published in the 60's. Chapters 3 through 5 are filled with single and multi-dimensional problems in cylindrical coordinates. With analytic solutions. There were other good texts used in the same time frame (Rosenow comes to mind).
Simply programming the solutions given in the texts will let you generate a perfectly adequate numerical solution (that is, a file of numbers) to test your own conduction code. And you'll know precisely what your test solution has in it.
Of course it's your problem and your time. And only you know exactly what you want to accomplish. Good luck!
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
Help with mass transfer in heat and water vapor exchanger mullenc525 CFX 7 January 25, 2011 23:26
Modelling heat transfer in wood May FLUENT 0 November 9, 2006 02:41
Modelling combustion and heat transfer Tudor FLUENT 4 May 9, 2005 07:02
