Why we use turbulence modeling?
Like Tree1Likes
Old   August 27, 2012, 08:28
Question Why we use turbulence modeling?
lnk
lnk
lnk is on a distinguished road
May I ask for a full answer to this basic question? Why we use turbulence modeling?
Thanks!
Best,
lnk
lnk is offline   Reply With Quote
Old   August 27, 2012, 08:40
Yon Han Chong
yonchong is on a distinguished road
Main reason is that we use meshes which does not have fine enough resolutions to capture all the fluid motion. If you have a fine enough mesh then you don't have to use any turbulence modelling and it is call Direct Numerical Simulation (DNS). Anything short on that you need some kind of modelling to count for the missing resolution.
yonchong is offline   Reply With Quote
Old   August 27, 2012, 08:49
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
as already stated, using turbulence modelling has an historical motivation, when computers were so poor that the computational grids were unable to solve for the whole range of scales...
Now, DNS can be a chance in some problems, at least of small/average scales. However, for industrial applications is very often prefered using turbulence modelling in CFD prediction for very rapid evaluations ... for them, using DNS is a tool to expensive computationally, what is more even if they use DNS very often the consequent database is too large to be managed.
Turbulence modelling will continue survive for long time ... but we are slowly swithing from RANS/URANS to LES formulations...
FMDenaro is offline   Reply With Quote
Old   August 27, 2012, 10:44
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
For almost every flow with practical relevance, it is simply impossible (and will be for the next few decades) to perform a DNS, e.g. to resolve all turbulent scales without modeling assumptions.
The limitation is the computational cost, which scales with Re^(9/4).
Additionally, engineers often only require Reynolds averaged values of the flow field, thus DNS or LES methods would simply be an overkill, even if applicable.
flotus1 is offline   Reply With Quote
Old   August 27, 2012, 15:01
leflix is on a distinguished road
Within less than 30 years, turbulence modeling will be completely useless since computers will be powerful enough to handle all range of scales until kolmogorov scale with DNS.
You will be able to solve the flow over a F17 at mach 3 on your play station during your breakfast
All turbulence modelers have only jobs for 30 years left , so do not start in this field if you don't want to turn jobless soon
leflix is offline   Reply With Quote
Old   August 27, 2012, 15:04
That's enough for me!!
Old   August 27, 2012, 15:15
At present time PS4 is available, you just have to wait PS9 or Iphone13 and it will be done
Old   August 27, 2012, 15:49
cfdnewbie
cfdnewbie is on a distinguished road
I am pretty sure that wont be the case, sadly enough... just increase Re by an order of magnitude, and you will blow up the systems but of course, the Re number we will be able to resolve will indeed increase drastically
cfdnewbie is offline   Reply With Quote
Old   August 27, 2012, 16:02
Yon Han Chong
I should have retired by then so I don't care.
Old   August 27, 2012, 16:34
bouhh you are defeatist cfdnewbie ! stay positive!!!
We shall continue this discussion in 30 years and you will see that I was right !
In 1950 the computers of that time needed 70 hours to compute the first 2000 digits of pi number. 50 years later a japanese guy Shigeru Kondo computed 135 millions of digits in 2h45mn on a simple pentium III...
I guess if we had said in 1950 to Von Neumann that we could compute 135 milllions of digits of pi in 50 years later in less than 3h ,while he was struggling with only 2000 digits he would have required that one send you in a psychiatric hospital.
The record by the same guy is 5000 billions of digits and it required 90 days of computations. If we had said this to Von Neuman he would have lost its mind immediatly
so you see...just be patient...
Old   August 27, 2012, 16:39
so you are safe !!!you can go on
Old   August 27, 2012, 17:08
Ford Prefect's Avatar
Ford Prefect is on a distinguished road
While I enjoy this discussion I am a bit more cautious. It seems to me that the time to solve a CFD problem has stayed more or less constant over time. With more computational power we just tend to add more cells and physics. Also, the information in DNS might not even be useful for some industrial applications, just think about how to get all boundary data for complex systems. I'd use a RANS model any day over DNS if it produced tolerable answers, well at least until the computers are so powerful that I won't even notice the difference in calculation time. Less is more, right?
"Trying is the first step to failure." - Homer Simpson
Ford Prefect is offline   Reply With Quote
Old   August 27, 2012, 17:25
That is so true!!!! We are never satisfied and we always want more when more is available! that's completely human!!!
But a time will come when our more secrets will, could be technically satisfied...Also over a limit it won't bring anything to keep increasing the number of nodes.
Old   August 27, 2012, 17:36
several years ago I ran simulations of 2d flows on a RISC-based computer and waited for days, now I run simulation of 3d flows on I7-based computer and ... wait for days!
Old   August 27, 2012, 17:53
yes I know this problem!! It's exactly what was saying Fordperfect
But in several decades you could perform ten times bigger cases on a massive computer with 10.000 I7 that you should have bought for few dollars in your super market while making your shopping for dinner
Old   August 27, 2012, 17:57
At that time I will mount them on my wheelchair ...
Old   August 27, 2012, 18:02
No because at that time wheelchairs will be old-fashioned Everyone could have an exoskeleton !!
Old   August 28, 2012, 03:28
truffaldino's Avatar
truffaldino is on a distinguished road
... and chip enchanced brain, so everyone will do DNS in his/her own imagination
truffaldino is offline   Reply With Quote
Old   August 28, 2012, 03:51
cfdnewbie
you guys having a party here? smoking some herbs?
Old   August 28, 2012, 04:05
... but ...this already happens now !
sbaffini likes this.
Turbulence Modeling RAJURAMAIAH Main CFD Forum 11 October 17, 2017 08:27
Turbulence Modeling meshkati FLUENT 1 October 3, 2016 06:11
Which Turbulence modeling???? Yapoo FLUENT 2 October 2, 2016 02:29
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 11:48
