September 20, 2012, 10:13 |
#21 |
Nick
Rep Power: 15 |
Viscous forces are not zero because there s a velocity gradient in the normal to wall direction but they are balanced by pressure difference forces .the.velocity for fully developed flow doesn't change in the parallel to wall direction .that means fluid particles don't accelerate because of the balance of forces
September 20, 2012, 10:52 |
#22 | |
Filippo Maria Denaro
Rep Power: 71 |
Your observation about the null lagrangian acceleration u * grad u is correct provided that you have a fully developed steady flow, this is only an academic framework. In the case you are citing it is the equilibrium of the isotropic to deviatoric part of the stress tensor that balance each other, since the isotropic part (the pressure) is of order rho*u^2 that leads to some misleading in the Re. Again, I don't see the problem in the definition of Re as ratio between convective and diffusive fluxes (or convective to diffusive time) ... both do not vanish... But the real flow in channel is far to be the Poiseulle solution, it is turbulent, with unsteady behaviour and inertial term always present, therefore I am used to define the Re in channel as rho*u_tau*H/mu wherein u_tau is the stress velocity that is defined by means of the pressure gradient |
September 20, 2012, 22:28 |
#23 |
Nick
Rep Power: 15 |
I think we can agree on the definition of Re based on the momentum comvective flux thru one.cross section divided by viscous flux ... I'm not convinced of the presence.of any inertial forces ..the flow.could be laminar too .anyways thanks for.your.input and.time
Particle Reynolds number calculation in Lagrangian tracking? | jiejie | OpenFOAM Running, Solving & CFD | 5 | July 6, 2012 04:47 |
Reynolds Number and Heat transfer Coefficient | panos_metal | FLUENT | 0 | January 7, 2011 06:37 |
Low Reynolds Number k-epsilon formulation CFX 10.0 | Chris | CFX | 4 | December 7, 2009 23:51 |
Reynolds Number | Matt | CFX | 0 | February 25, 2009 05:40 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
