October 9, 2012, 05:51 |
problem in DNS in a pipe
SAM
Rep Power: 14 |
Hi guys
I am running a DNS code in a pipe. For laminar flow I have a problem. as you see in 2d plot of radial velocity at inlet, there are some strange number of velocity. it should be zero but it is not. I will appreciate any help. |
October 9, 2012, 06:20 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
are you solving incompressible flows? did you check the divergence-free constraint in each cell? Are you sure of the numerical stability contraints? From the figure it seems that the radial velocity accounts for the wall and the incipient boundary layer in a very low Re flow with plug velocity inlet, but I may be wrog ... |
October 9, 2012, 07:58 |
#3 | |
SAM
Rep Power: 14 |
I am so grateful for your answer. the Re=60 based on friction velocity. number of mesh is: r=30 theta=16, z=96. Yes this is for incompressible flow. the divergence is Ok. I am using the profile ((Re/4.)*(1.- 4.*(rp(i))**2.)) for inlet which is analytitical solution. I put radial and tangential velocity 0 at z=0 . |
October 9, 2012, 09:46 |
#4 | |
Rep Power: 71 |
After you have to refine the grid and see what happens, usually the small value in the normal-to-wall velocity component can be controlled. See also your threshold value in the pressure solver, can be to high. After that, you can check further by changing the inflow/outflow condition in a periodic condition, this way you can check the inner solution. |
October 22, 2012, 12:10 |
how strange the velocity is? Can you email me and we can discuss furtherly.
#5 | |
kuihe
3D Swirl flow in the pipe: convergence problem | Sachin U. Nimbalkar | FLUENT | 5 | December 22, 2016 01:34 |
[ICEM] Using a hybrid mesh for a simple pipe | Udio_NT | ANSYS Meshing & Geometry | 17 | October 18, 2012 14:42 |
simpleFoam convergence problems for pipe flow problem | Mike Graham | OpenFOAM Running, Solving & CFD | 0 | January 30, 2012 14:40 |
Problem meshing very thin pipe | B. Hemmen | FLUENT | 2 | May 16, 2006 08:29 |
DNS to Eigenvalue -> Cauchy Problem. HOW? | RMG | Main CFD Forum | 0 | February 12, 2004 05:45 |
