About the level-set method.
Old   February 20, 2006, 19:42
Default About the level-set method.
maximus
hi,I am trying to use the level-set method to deal with a moving boundary problem. but It's the first time for me to use level-set method ,so I was confused at the first step.The interface in my problem is an arbitrary irregular curve, so how to give the sign distance funtion at the initial time in the whole field,or how to compute the distance from a point to an arbitray curve? I feel it is not an easy task while I can't find any discription on it in the papers I have reviewed. Maybe my problem is not a problem just because I am not familiar with the level-set method. So I appreciate any suggestion and help. Thanks a lot!!
Old   February 21, 2006, 01:31
Default Re: About the level-set method.
yukai
try to find some important papers, J.A. Sethian, M. Sussman etc. check this out: people.tamu.edu/~yukai/
Old   February 22, 2006, 04:13
maximus
thank u for ur response,Mr Yu! I have visited your homepage and found many useful links. Also I found many fascinating results in ur research. Because I am still a beginner in Level set methods, I wonder if I can send mail to u for some suggestions.
Old   February 23, 2006, 01:39
yukai
no problem
Old   November 4, 2010, 09:16
Default How to set the initial signed distance function
David
hydrol88 is on a distinguished road
Hi!!! I also have the same problems. I am trying to use the level-set method now. I am confused at the first step for the signed distance function.The interface in my problem is an arbitrary irregular curve, Could you let me know how to give the sign distance funtion at the initial time in the whole field,or how to compute the distance from a point to an arbitray curve? Thanks.. Help me..
hydrol88 is offline   Reply With Quote
Old   November 4, 2010, 14:33
Default Initialize Level Set Function
Hans Bihs
valgrinda is on a distinguished road
For the initialization of the level set function, try this:
1) Give all cells with Phase 1 the level set value +1
2) Give all cells with Phase 2 the level set value -1
3) Reinitialize (see Sussman,1994 and Peng,1999)
Result: Level Set Function is a Signed Distance Function with the Eikonal Equation fulfilled, the zero level set gives the interface between Phase 1 and Phase 2.
valgrinda is offline   Reply With Quote
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
level set method for simulating detonation Amir Main CFD Forum 4 July 31, 2008 15:13
Problem on high density ratio in Level Set method Kai Yan Main CFD Forum 10 December 25, 2007 06:12
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Free surface level set and roe Angela Main CFD Forum 3 October 25, 2002 04:12
