2 Different Transonic Small Disturbance Equations?
Old   February 22, 2006, 13:42
Default 2 Different Transonic Small Disturbance Equations?
Frank
Hello Folks, I am currently looking at solutions of the transonic small disturbance. It seems, however, that there are two different forms of the equation and I'm unsure why this would be the case.
One form (as found in the famous Murman & Cole Paper of 1971 - the "Karman-Gudrely" equation) comes from a singular perturbation technique using the airfoil thickness ratio 'tr' as a small parameter. The equation is given as
(K -(gam +1)*P_x)*P_xx + P_yy =0
where K is a similarity constant including the mach number 'M' and thickness ratio 'tr': K=(1-M^2)/tr^(2/3). 'P' is the velocity potential 'gam' the thermodynamic constant and _x denotes differentiation w.r.t x.
I have seen another form of the equation which seems inconsistent with the KG equation, however: (1-M^2)*P_xx - (gam+1)*M^2*P_x*P_xx + P_yy =0;
By substituting the expression for K into the above expression the 2 equations are different. The two equations are both used to solve for flow around an airfoil with the same boundary conditions. I can't understand how two different equations can correspond to the same physical system. The second of the two equations doesn't even contain the airfoil thickness ratio!
Could someone please shed some light on this issue?
Cheers F
Old   February 22, 2006, 23:44
Default Re: 2 Different Transonic Small Disturbance Equati
Praveen. C
In the second equation, the spatial coordinates have not been made non-dimensional. These equations are application for M very close to 1 with M>1. In the first form, the M<sup>2</sup> multiplying (&gamma;+1) has been approximated as 1.
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 03:19
CFD governing equations m.gos Main CFD Forum 0 April 30, 2011 14:21
AVL Fire transonic simulation Ainil Main CFD Forum 1 August 24, 2010 15:53
Small Disturbance Transonic equation! Kyung-Seok, Kim Main CFD Forum 1 July 6, 2004 02:50
Transonic small disturbance equation Kaveh Ghayour Main CFD Forum 1 July 26, 1998 05:23
