Cavity flows with Projection method(Kim&moin) |
October 31, 2012, 09:47 |
yh.jung
Hello guys. !
I'm studying Cavity flows with projection method. In my fortran code, i used ADI method to solve pressure and NS equations. But in case of over re=400, it does not converges ... I have checked divergence and pressure residual for convergence. Is there anyone who have any comments on me? I don't know why it blows up. |
October 31, 2012, 12:37 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
How about your divergence error? |
November 1, 2012, 04:52 |
lemee.thomas@gmail.com
Dear Nanbrain,
From what I understand in your post, you use the projection Method as in the paper of Kim and Moin. But above Re=400, you can't have the convergence. Many reasons can lead your code not to work. Did you write your code as the publication? Did you follow every step? I'm pretty sure, yes. So FMDenaro is right! What is your time step? What is your grid size? The error can come from the criteria of stability of the code. Indeed your time step is may be to high or your mesh size top small. It's may be an issue. Thomas_L |
cavity flow, projection method |
Realizable k-epsilon model for cavity flows | vasuaero1988 | FLUENT | 1 | September 27, 2010 03:06 |
cavity in flat plate and drag prediction | Far | FLUENT | 0 | May 19, 2010 14:47 |
drag of flat plate with cavity | Far | FLUENT | 0 | May 18, 2010 04:57 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Lid-driven odd-ball cavity flows | Jim Park | Main CFD Forum | 2 | February 19, 2002 16:00 |
