Stanton Number and Arbitrary Surface Temperature
Old   March 8, 2006, 21:36
Default Stanton Number and Arbitrary Surface Temperature
Boris Vaisman
Hello everyone,
-- problem --
Please advise, how would you calculate the Stanton Number (St) on flat plate with an arbitrary surface temperature? Per se, if air inlet temperature (T_in) is 1000 and the plate surface (T_w) goes from 500 to 1000.
What is the proper way to calculate St?
-- details --
In general St = q_w(x)/(rho*c_p*u*dT), where: - rho, c_p, and u are evaluated at free stream values - q_w(x) is evaluated at the wall - dT is either a reference value or T_in-T_w(x)
My dilemma is a follows.
(1) If dT is a constant reference value, St would change sign, as T_w changes from T_w<T_in to T_w>T_in. This seems to contradict all definitions of the Reynolds Analogy Factor (R). Consider von Karman or Spalding and Chi, R is always positive and constant or almost constant.
(2) On the other hand, if dT(x)= T_in-T_w(x), there will be a point where q_w(x) changes sign (for the above scenario), but dT(x) has not changed sign yet (for a short distance). This will cause St to explode. This is also problematic.
Thank you very much for your time and help.
Boris Vaisman
Old   March 9, 2006, 04:43
Default Re: Stanton Number and Arbitrary Surface Temperatu
versi
In my case, St number is St = q_w(x)/(rho*u*dH), where dH= H_in-H_w, H is total enthaphy=h + q^2/2. Unless singificantly heating from interior, dH always >0.
conjugateHeatFoam with arbitrary number of region maddalena OpenFOAM 7 July 31, 2020 04:14
scalarTransportFoam for arbitrary number of transported scalars andreasp OpenFOAM Programming & Development 6 June 5, 2011 15:58
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
