Question about time step setting for different turbulence modeling
Old   November 16, 2012, 07:18
Question Question about time step setting for different turbulence modeling
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
May I ask shall I use different time step for different turbulence modeling? Why?
My simulation converges well with K-Omega model with time step = 10^(-4)s. Shall I use a larger or smaller time step for reynolds stress models?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   November 19, 2012, 02:09
atmcfd's Avatar
ATM
atmcfd is on a distinguished road
A very vague answer, but yes., and I am not sure of the time step you need for the RS model, without knowing the case.
Generally, It also depends upon the numerical scheme you are using for timestepping (implicit or explicit). Usually, if you are not sure, I would suggest running smaller time steps for any turbulence model initially.this is to be safe and make sure the simulation does not become unstable. Some turbulence models which focus a lot on explicitly "resolving" considerably small turbulent scales would definitely require small time steps, eg highly resolved LES , on a very fine grid. Likewise, flows in cases where you expect to see large transients would also need smaller time steps, since it would better resolve the transients you want to see. More importantly, the simulation would not diverge (unless of course, there are errors elsewhere, like B.Cs etc..)
atmcfd is offline   Reply With Quote
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 07:56
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 15:24
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 10:23
Warning 097- AB Siemens 6 November 15, 2004 04:41
