what is the meaning of "weak form "
Old   March 16, 2006, 07:39
Default what is the meaning of "weak form "
ztdep
what is the meaning of " weak form of the N-S equation", regards
Old   March 16, 2006, 09:06
Default Re: what is the meaning of "weak form "
ag
When the equations are written in differential form certain assumptions are implied concerning the smoothness of allowable solutions. In order to allow for discontinuous solutions, these assumptions have to be weakened by resorting to an integral form of the equations. With the integral form, a wider range of solutions can be supported, including discontinuous solutions.
Old   March 20, 2006, 03:09
al
As it was mentioned by ag, we can not work with the called "strong form" of the problem due to the requirements, regularities, continuity, ... For that reason, the problem is normally reduced writting it in a "weak form". This is not limited to FEM or SEM types of methods and is the case in general. For example, if you are using FDM, or FVM you are using a "weak form", where to find the solution to the original problem consist in finding a set of values (at the discrete points) that are satisfing the discrete formulation of the problem.
RANS in integral form siw Main CFD Forum 0 August 17, 2010 03:18
What's meaning of UDF FUNCTION zhaoxinyu Fluent UDF and Scheme Programming 0 March 31, 2010 08:04
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
Fractional step in ALE form - possible? Wee Main CFD Forum 2 October 3, 2006 10:20
Get data in i,j,k forrmat ather than FE form Puneet FLUENT 0 November 19, 2003 12:40
