how to find lift and drag in autodesk simulation cfd 2013
Old   February 6, 2013, 03:00
Default how to find lift and drag in autodesk simulation cfd 2013
vijay
vijay007 is on a distinguished road
Hello sir
I'm vijay from india please guide how to find lift and drag in autodesk simulation cfd 2013 with clear details please help
thank you
with regards
vijay John
vijay007 is offline   Reply With Quote
Old   February 6, 2013, 08:32
Mark Decker
marktm250xc is on a distinguished road
In the Results menu, choose the Wall Calculator, select all the surfaces that you want to have lift/drag calculated, check the Force option and the press the Calculate button.
marktm250xc is offline   Reply With Quote
How to find Lift and Drag in postprocessing step once the simulation is done mou_mi OpenFOAM Post-Processing 11 August 8, 2013 00:48
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 10:38
lift and drag in 2d simulation chelvistero OpenFOAM 0 June 14, 2010 04:09
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 27, 2007 23:38
Find Mean Drag and Mean lift using LES Cfd-Student FLUENT 1 January 9, 2006 11:03
