January 30, 2013, 07:31 |
Non Boussinesq approximation
Hari
Rep Power: 13 |
I need to simulate natural convection in square cavity (bottom wall heated) without using Boussinesq approximation. I need to take the density changes into account with non-Boussinesq approximation. Can I solve this with an incompressible solver with treating density as constant? I need help about the formulation and way of solving. With regards, Hari |
January 30, 2013, 08:15 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
February 5, 2013, 08:04 |
Hari
Rep Power: 13 |
Thank you for replying. I need to develop a pressure based solver without boussinesq approximation. Is it possible to work on incompressible flows without treating density as constant.
February 5, 2013, 08:37 |
Rep Power: 18 |
If the density can vary, then the flow by definition is not incompressible. however, you can develop segregated solvers for variable density flows. One example of such a solver can be found in a JCP paper by Hou and Mahesh. If you put their names into google scholar, the second or third entry will point you to a pdf version of that paper.
February 5, 2013, 09:42 |
Hari
Rep Power: 13 |
Thankyou for replying.
I was referring to the following ASME J.heat transfer paper where they say the flow is incompressible with non boussinesq approximation in a differentially heated cavity. I have mentioned the details of the paper below. A Numerical Simulation of Combined Radiation and Natural Convection in a Differential Heated Cubic Cavity P. Kumar and V. Eswaran J. Heat Transfer,2010,Volume 132,Issue 2, |
February 5, 2013, 10:28 |
Jonas T. Holdeman, Jr.
Rep Power: 18 |
But doesn't "incompressible" just mean that the density is not a function of pressure? Isn't constant density just an additional simplification? I would think that an (idealized) incompressible fluid could still have the density a function of temperature or concentration. Isn't bouyancy just the result of density differences?
February 6, 2013, 09:01 |
#7 | |
InterFoam with boussinesq approximation | sinusmontis | OpenFOAM Running, Solving & CFD | 2 | October 25, 2020 12:21 |
Boussinesq approximation, help please! | engahmed | FLUENT | 0 | May 20, 2010 11:25 |
Question on boussinesq approximation | panos_metal | FLUENT | 1 | January 11, 2010 11:18 |
boussinesq approximation | jamal | FLUENT | 2 | March 25, 2008 08:57 |
Boussinesq approximation again | Gabriel | Main CFD Forum | 3 | May 11, 2000 09:24 |
