Pressure velocity decoupling in low mach compressible flow
Old   February 13, 2013, 03:47
Smile Pressure velocity decoupling in low mach compressible flow
Meeranandan is on a distinguished road
I'm working on low speed compressible navier stokes equation to simulate heat transfer in differentially heated cavity (Say left wall heated and right wall cold). Will there be pressure velocity decoupling eventhough I use equation of state to compute pressure? Is it better to solve the equations by pressure based method or density based method? I dont want to use Boussinesq approximation.
with regards,
Meera
Meeranandan is offline   Reply With Quote
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 21:08
low speed compressible flow lily CFX 2 November 16, 2005 05:15
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
