is time in unsteady problems exactly equivalent to what occurs in nature? |
February 19, 2013, 15:24 |
Ehsan
Rep Power: 26 |
I've faced with a essential problem and doubt about what i set forth at the title.for example at simple cavity problem at 1micro second are pressure and velocity equal exactly and precisely to what experiment shows.does it takes same time to reach steady state as takes place in nature?or about other unsteady problems.
Can anyone submit a reasonable answer to this doubt? |
February 19, 2013, 15:29 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
To be formally equivalent with an experiment, you should prescribe exactly the same initial and boundary conditions. For laminar flow you can be quite confident that you can reproduce a natural time-evolution for sufficiently fine grid. For turbulence the problem is much more complex ... |
February 19, 2013, 17:18 |
Ehsan
Rep Power: 26 |
then your answer seems yes or nearly yes.in turbulent flows may be very small difference to what occurs in nature but in laminar if initial and boundary conditions be defined precisely we can trace phenomena accurately at same time evolution.am i correct?
thanks. |
February 19, 2013, 17:26 |
Martin Hegedus
Rep Power: 19 |
To be truly time accurate one must use the compressible, rather than incompressible, set of equations to capture the pressure wave. However, for low speeds, that means there will be a big time scale difference between the rate at which the particles and pressure wave travels. I'm not sure what error is incurred by using the unsteady incompressible equations. Hopefully it's small.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
