Outlet boundary condition
Old   May 5, 2006, 16:51
Default Outlet boundary condition
Asghari
Hello,every body. please,take into consideration,two bottom example that must be solved by cfd: 1-The flow entered into cylinderical and axisymmetric tube. Wall temperature in upstream is 350 kelvin and wall temperature in downstream is 300 kelvin. 2-There is two cylinderical and concentric tube ; first fluid entered from inner cylinderical duct in 300 kelvin and second fluid entered from space between inner and outer cylinder and in opposed direction(countercurrent)with first fluid and in 350 kelvin . Please,for two given example,answer to this common question: a)It is clear that outlet boundary condition in first example , is not fully developed condition(because of temperature is changing from inlet to outlet),therefor , please, describe that how to define outlet boundary condition? b)In second example, what is outlet boundary conditions for both flow?(fully developed condition could not used due to temperature variations from upstream to downstream for both fluid.)
Outlet Pressure-flow coupled boundary condition (Windkessel) cfdfsi Fluent UDF and Scheme Programming 3 July 21, 2017 12:30
Boundary Condition outlet natantyt FLUENT 0 September 27, 2010 15:30
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
inlet and outlet boundary condition for turbomachinery solution siamak1424 OpenFOAM 2 August 15, 2009 11:14
Outlet boundary condition CN FLUENT 6 May 22, 2005 09:37
