Wall function's solving procedure.
Old   March 5, 2013, 03:15
Default Wall function's solving procedure.
Dongyue Li
sharonyue is on a distinguished road
Hi guys:
In Wall functions. there are lots of functions as follows.What confused me is how to solve this bunch of functions?I know the main idea of wall functions. but how to solve it? Thanks.
sharonyue is offline   Reply With Quote
Old   March 5, 2013, 11:16
Lefteris
Aeronautics El. K. is on a distinguished road
Do you mean how to calculate y+ prior to the simulation of the flow, when you create the mesh?
Estimate the shear stress (by calculating the skin friction coefficient with one of the many formulas) then calculate Ut and then you can solve for y+.
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   March 5, 2013, 18:52
Dongyue Li
Hi Lefteris,
Yes, Are you sure about estimating the shear stress?
If I have the shear stress,I have the friction velocity,but if I want to know y+,I dont know k, how can I get k?
And seems according to this formula,you can caculate y+ only by y and k.
Thanks.
Old   March 6, 2013, 06:30
Lefteris
Hello Forrest,
(Cμ^0.25)*(k^0.5) is the shear velocity.
However, I usually use the formula y+=(ρ*Ut*y)/μ which is the same with the one you use but I estimate the shear velocity through the shear stress and therefore I don't have to use the k.
Lefteris
Old   March 6, 2013, 20:44
Dongyue Li
Okay, Thanks, I got it.
First I need to caclulate the skin friction coefficient by moody picture and other things, then I get shear stress. according to shear stress,I have shear velocity,and I have yplus.
After I have yplus I can get k and U ,epsilon in the P node which can be treated as boundary conditions. but how can I get pressure in node P?
I think if I have k,epsilon,U,P,I can integrate the KE model in the main flow and get the solution.
Old   March 7, 2013, 05:10
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
You take all unknown values from the iteration before, or from the initialization. You can not know all of them at the same time, because then you would know the result...
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   March 22, 2013, 06:33
Dongyue Li
Hello Forrest,
I attach my procedure, I dont know if its rite...still I am confused about it.
To Rodriguez:
I dont know where to start my iteration ...
Old   March 22, 2013, 08:33
Lefteris
Hello Forrest,
You don't have to make an assumption for Uτ since you can compute it from the formula Uτ=sqrt(τw/ρ), where ρ is the density and τw the shear stress which can be computed from the formula τw=Cf*(0.5ρU^2). In order to estimate Cf, choose a formula from here: http://www.cfd-online.com/Wiki/Skin_...on_coefficient
Lefteris
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
