CFD of flapping wing mav
Like Tree3Likes
  • 1 Post By cdegroot
  • 2 Post By cdegroot
Old   November 4, 2012, 10:41
Default CFD of flapping wing mav
sultan
sultan is on a distinguished road
i am trying to do fluid structure interaction of flapping wing mav as part of my final year project of bachelor of aerospace engineering,but before doing fsi i need to do cfd of flapping wing.so please guide me how to do cfd of flapping wing mav
sultan is offline   Reply With Quote
Old   November 4, 2012, 11:15
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
What software do you have access to? ANSYS can do FSI. If you have access look up the tutorials and if you have problems post to the appropriate sub forum with a specific question or problem
daldry likes this.
cdegroot is offline   Reply With Quote
Old   November 4, 2012, 12:50
sultan
i am to use ansys or nastran.which one would be better for cfd of flapping wing?
Old   November 4, 2012, 14:47
cdegroot's Avatar
Chris DeGroot
I have no experience with Nastran, but Ansys can do FSI. It's a tough problem though. See what you can do with a simplified geometry. If you have problems these forums are a great source of help.
Old   November 5, 2012, 03:03
sultan
Have you done it before?or has somebody else you know
Old   November 5, 2012, 06:57
cdegroot's Avatar
Chris DeGroot
I haven't done a flapping wing nor do I know anyone that has. Do you need to do FSI or can it just be a moving mesh problem? i.e. do you care about the mechanical deformation of the wing and its interaction with the flow or can you assume it is a rigid wing moving in the flow. It's easier if it's just rigid. The hard part is that moving meshes can be less robust when the deformation is large.
Old   November 5, 2012, 07:48
sultan
Actually i am to do one-way fsi of flapping wing my geometric model will only be wings of the micro air vehicle executing flapping motion.in one-way fsi there is no feedback loop i.e the aerodynamic loads wont change as a result of deformation(if deformations are considered small enough that they dont change the aerodynamics of the body then i think one way fsi is sufficient).can i consider the wing as rigid and run its cfd to find aerodynamic loads and then use those loads to find deformations?would doing cfd of rigid wing executing flapping motion like a bird be easy or doable?
Old   November 5, 2012, 09:09
cdegroot's Avatar
Chris DeGroot
I don't want to make too many claims because I am not an expert in FSI; just an occasional user of such models in commercial software. I would say that if you are interested in the deformations due to the loads you are doing the right thing by choosing one-way FSI. I think this is easier than running the flow calculation followed by a calculation of the deformation.
I am hoping someone else can weigh in on your question. I know ANSYS software is capable of running the calculations you mention, I just don't have the experience to say whether it is doable or not.
If you want my opinion, I would not start with the full wing geometry you want to solve in the end. Start with something simpler. Maybe take a cylinder and make it move in the domain to see if you can get that to work. You want something that will run quickly to test the setup before you commit to the final geometry which will probably take a while to run. In CFX there are a few tutorial problems on two-way FSI. Do these first to get familiarized with the program.
Old   November 5, 2012, 09:59
sultan
Thank you for your help im obliged.as i am new to this forum please guide me how can i attract other experts to answer this post.
Are u a student?which field?
Old   November 5, 2012, 10:07
cdegroot's Avatar
Chris DeGroot
You are welcome for the help. For more help, you should post to the sub-forum for the software you are using (i.e. Fluent, CFX, etc.). You will find lots of help there. I read the CFX forum regularly. As for me, I have a PhD in Mechanical Engineering specializing in CFD and am currently working at a University in collaboration with one of the major CFD companies on some development work.
Old   November 6, 2012, 08:12
sultan
Whats the difference between cfx and fluent?which one would be easier to use in case of my problem?
Old   November 6, 2012, 08:55
cdegroot's Avatar
Chris DeGroot
The main difference between CFX and Fluent is that CFX is based on a control volume finite element method (also called vertex centred finite volume method) and Fluent is based on a cell centred finite volume method. Both programs should work for your problem. My preference is CFX because I find that it is more user friendly and I like the coupled solver (Fluent has a coupled solver too, but seems like more people use it's segregated solver). The thing I like best about CFX is the CFX Expression Language which makes it very easy to define custom boundary conditions, source terms, etc. Fluent has User Defined Functions, but they are not as user friendly in my opinion (they require coding and compiling). This is just a personal preference though; Fluent is also a good code.
cfd seeker and Rakeshvb like this.
Old   February 28, 2013, 19:01
daldry is on a distinguished road
I want to do the same thing! have you found some resources or tutorials!?
daldry is offline   Reply With Quote
DEFINE_CG_MOTION for flapping wing UDF xyzch001 Fluent UDF and Scheme Programming 21 February 7, 2022 07:47
DEFINE_CG_MOTION for flapping wing UDF xyzch001 Fluent UDF and Scheme Programming 0 December 14, 2011 08:39
Modelling flow around a flapping wing balkrishna Main CFD Forum 1 February 18, 2010 23:32
CFD of Flapping Wings Yogesh babbar Main CFD Forum 1 July 15, 2006 08:28
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
