CFD Anderson.. Chapter 10: Supersonic Flow over a Flat plate
Like Tree1Likes
Old   August 14, 2013, 09:34
Default c code
  #21
Kerala
sreelalmr is on a distinguished road
Originally Posted by venkateshaero View Post
if u want similar code in C . i will give u
i also need the code please sent me sreekonchira@gmail.com
sreelalmr is offline   Reply With Quote
Old   August 21, 2013, 17:31
shashi kumar
shashi kumar is on a distinguished road
can u send me a copy to me at karankumar9931034374@gmail.com
shashi kumar is offline   Reply With Quote
Old   October 17, 2013, 14:55
Default M25 case for supersonic flow at 200,000ft
  #23
sandy
archeoptyrx is on a distinguished road
Has anyone done the second case in Anderson CFD book ?
Mach=25
Alt=200,000ft (60km)
L=0.005;
I tried it and it gives me complex numbers. i used the free stream properties at that altitude.
I used the same 70*70 grid .
should i be missing something ?
archeoptyrx is offline   Reply With Quote
Old   February 11, 2015, 09:44
Default Matlab code
  #24
ivan_CFD is on a distinguished road
I have uploaded a Matlab code that solves the original problem. It can be downloaded from MathWorks here: http://www.mathworks.com/matlabcentr...r-a-flat-plate
Hope this helps!
ivan_CFD is offline   Reply With Quote
Old   July 11, 2020, 01:17
Default C code
  #25
Srijit Sen
srijit is on a distinguished road
Can you please send the code to srijitsen98@gmail.com Thank you!
srijit is offline   Reply With Quote
supersonic flow
Low Reynolds Number Flow over a Flat Plate Go FLUENT 4 August 28, 2013 05:19
Flow over a flat plate vasanthkch OpenFOAM 1 December 19, 2011 14:57
2d supersonic flow over flat plate puzzled Main CFD Forum 2 March 17, 2004 18:07
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Turbulent flow over flat plate Narayanan Main CFD Forum 1 May 8, 2000 07:03
