April 14, 2013, 16:00 |
Porous media
Rep Power: 14 |
Hi CFD users! I have one problem. I simulate (in Fluent 14.5 version) the flow of water through the row of paralel tubes. Tubes are simulated as porous zones with different power (source terms) and every tube is divided to 4 parts (down to up). I defined walls between tubes - with no heat flux, so the boundary condition is isotermic. Walls are not divided to 4 parts as tubes. My problem is following: there should be isotermic condition along the whole wall and there is the wall, but in temperature contours, it seems as expansion of flow ("bubble" of different temperature) but only in small areas in points where two porous parts of tube touch to each other. I dont know, if there is some mistake in setting of porous zone placed next to other porous zone, or if i have to divide the wall to 4 parts in a same case as the tube is divided, or where is the mistake? So do you have some similar experiences in defining walls placed between two (or more) porous zones?
Thanks a lot for your recommendations and advices. |
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 7 | May 14, 2020 16:34 |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 04:09 |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 10:34 |
species mass source in porous media ? | PK | FLUENT | 0 | February 16, 2007 11:12 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
