8 vortices in a channel
Old   June 10, 2006, 03:49
Default 8 vortices in a channel
ztdep
Hi:
I have a homework to simulate the turbulent flow in a channel, my teachear saied there are 8 vortices in the channel, so which turbulent model should i use! thank you
Old   June 10, 2006, 05:14
Default Re: 8 vortices in a channel
ganesh
Dear ztdep,
The number of vortices has no relation whatsover with the trubulence model you employ. One of the good models that have been found succesful for internal and external flows even with moderate adverse pressure gradients is Menter's k-w SST model. Wilcox k-w model would also be a good choice, though it suffers from the freestream dependency problem.
Hope this helps Regards,
Ganesh
Old   June 10, 2006, 07:55
diaw
diaw writes:
Have you tried simulating with transient DNS, with no convection stabilisation?
Old   June 10, 2006, 22:38
ztdep
Hi:
ganesh, thank you for your response!
But some studuents can not predict the vortices with a standard k-e model,
I will try the models you have suggested! Thank you again!
Old   June 10, 2006, 22:40
ztdep
Hi:
diaw, would you like to give some information about some free DNS code!
Thank you !
Old   June 10, 2006, 22:51
diaw
Hi ztep,
If you email me the model geometry (channel shape) & flow parameters, I'll have an initial go at it using a rather unconventional approach.
I can then send you the results & let you try & have a go on your own. If it works out, then I'll let you have a copy of the model code-file & you can try for yourself.
It would be based on open-source, downloadable software.
diaw...
Old   June 12, 2006, 00:17
ztdep
Hi:
diaw, it is only a 3 dimensinoal straightn square channel, the renolds number based on the Uin and the weight of the channel is 10000!
ztdep@yahoo.com.cn
Thank you very much!
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 16:26
tecplot 3D velocity contours inside a channel vetnav Tecplot 4 July 14, 2010 20:03
About Cooling channel alefem FLOW-3D 1 May 28, 2010 11:15
Open Channel Boundary Conditions via journal Matteo FLUENT 0 January 21, 2008 11:05
Simulation of Longitudinal Vortices in a channel shiraz FLUENT 0 December 14, 2006 12:29
