Porous media
Like Tree1Likes
  • 1 Post By roupcik
Old   April 14, 2013, 16:00
Default Porous media
roupcik is on a distinguished road
Hi CFD users! I have one problem. I simulate (in Fluent 14.5 version) the flow of water through the row of paralel tubes. Tubes are simulated as porous zones with different power (source terms) and every tube is divided to 4 parts (down to up). I defined walls between tubes - with no heat flux, so the boundary condition is isotermic. Walls are not divided to 4 parts as tubes. My problem is following: there should be isotermic condition along the whole wall and there is the wall, but in temperature contours, it seems as expansion of flow ("bubble" of different temperature) but only in small areas in points where two porous parts of tube touch to each other. I dont know, if there is some mistake in setting of porous zone placed next to other porous zone, or if i have to divide the wall to 4 parts in a same case as the tube is divided, or where is the mistake? So do you have some similar experiences in defining walls placed between two (or more) porous zones?
Thanks a lot for your recommendations and advices.
2271554457 likes this.
roupcik is offline   Reply With Quote
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 7 May 14, 2020 16:34
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
species mass source in porous media ? PK FLUENT 0 February 16, 2007 11:12
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
