September 28, 2011, 11:52 |
OpenMP
Here is an OpenMP implementation of a Laplace solver (a parallel Fortran code). I can get a good speedup on up to 4 processors, but it does not improve when I use more processors. Could you please let me know how I can get a better speedup by using more processors? program lpomp integer imax,jmax,im1,im2,jm1,jm2,it,itmax parameter (imax=4001,jmax=4001) parameter (im1=imax-1,im2=imax-2,jm1=jmax-1,jm2=jmax-2) parameter (itmax=200) real*8 u(imax,jmax),du(imax,jmax),umax,dumax,tol parameter (umax=10.0,tol=1.0e-6) call omp_set_num_threads(2) !$OMP PARALLEL DEFAULT(SHARED) PRIVATE(i,j) !$OMP DO do j=1,jmax do i=1,imax-1 u(i,j)=0.0 du(i,j)=0.0 enddo u(imax,j)=umax enddo !$OMP END DO !$OMP END PARALLEL it=1 dumax=1.0 !$OMP PARALLEL DEFAULT(SHARED) PRIVATE(i,j) ! Main computation loop do it=1,itmax dumax=0.0 !$OMP DO REDUCTION (max:dumax) do j=2,jm1 do i=2,im1 du(i,j)=0.25*(u(i-1,j)+u(i+1,j)+u(i,j-1)+u(i,j+1))-u(i,j) dumax=max(dumax,abs(du(i,j))) enddo enddo !$OMP END DO !$OMP DO do j=2,jm1 do i=2,im1 u(i,j)=u(i,j)+du(i,j) enddo enddo !$OMP END DO enddo !$OMP END PARALLEL stop end Compile: ifort -openmp -parallel Laplace.for Thanks! |
How to parallelize this fortran code by openmp | ronac | Main CFD Forum | 1 | May 11, 2016 02:12 |
OpenMP in Junction Box Routine | Hannes_Kiel | CFX | 10 | September 21, 2010 13:51 |
About the OpenMP | jinwon park | Main CFD Forum | 5 | August 28, 2007 05:47 |
OpenMP and fortran | John Deas | Main CFD Forum | 0 | May 17, 2007 16:53 |
Parallel computing and OpenMP | ganesh | Main CFD Forum | 7 | October 27, 2006 10:15 |
