CFL in dual time stepping with implicit scheme
Old   May 8, 2013, 23:01
Default CFL in dual time stepping with implicit scheme
Dokeun, Hwang
dokeun is on a distinguished road
Dear CFDers
I think I don't understand clearly about physical global time step and pseudo time step.
The problem is that when I uselarge CFL number (10^4~10^6) using implicit scheme for pseudo steady solution, then physical time marching is too fast and the solution arrives at final time I set.
I think I may have misconception about computing physical global time step.
What I understand about dual time stepping is as below
During pseudo time stepping, local time step is computed at every iteration and update pseudo steady solution.
If the unsteady residual is converged enough(order of 10^2~10^4), then get out of inner loop and compute physical global time step extract minimum value among the local time steps.
Even though I have minimum value of local time step(pseudo time step at converged moment) contains large CFL number and it makes physical time step large.
Please correct my misunderstanding.
thank you in advance
Meanwhile I found a clue (http://cdlab2.fluid.tuwien.ac.at/LEH...ug/node898.htm)
In the last sentence, physical time is defined only by desired accuracy. Does it mean that global time step is just user defined value?
dokeun is offline   Reply With Quote
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Problem with parallel python scripts for dual time stepping test case sss3700 SU2 1 March 5, 2013 13:30
time stepping in implicit way varghese FLUENT 4 February 28, 2003 03:34
Dual Time Stepping Method X. Ye Main CFD Forum 1 September 23, 1999 04:05
