March 4, 2013, 07:32 |
2-way FSI, System Coupling error
Rep Power: 13 |
Hello, everybody!
I am trying to perform a 2-way FSI considering a gas compressor blade. So, I linked Transient structural with Fluid flow (Fluent), and connected the setup cells of those with System Coupling. When I update the Solution cell of the System Coupling I get the following message: System coupling run completed with errors: the MAPDL beginning time 1 is different from the System Coupling service beginning time 0. Does anyone can tell what should I do to settle it? |
2-way fsi, beginning time, system coupling, system coupling error, the mapdl |
Problem running perturbUCyl | sen.1986 | OpenFOAM | 17 | June 4, 2019 05:56 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
