BFS...again
Old   August 19, 1999, 04:16
Default BFS...again
Jan Ramboer
Here I am again with my backward facing step. I tried a few boundary conditions on the outlet. Now when I used the boundary condition on the Rieman invariants described by Hirsch, Internal and External flows. for the outflow. on the inflow I used an imposed velocity and temperature. Now it converge very wel but when convergence is almost reached it suddenly blows up. Is it because the outflow and inflow boundary conditions are incompatible?
Greetings,
Jan
Old   August 19, 1999, 04:27
Default Re: BFS...again
John C. Chien
(1). Don't expect readers to dig up or guess at what you did before, if you expect interested readers to answer your question. (2). It is essential to state your problem in terms of: steady vs transient, laminar vs turbulent, compressible vs incompressible, and this Rieman invariant method. (3). Readers answer your question not just for you, it is for the rest of the readers. It is really expensive on Internet.
Old   August 19, 1999, 05:40
Jan Ramboer
OK let me state my problem again, I am solving a 2D compressible turbulent backward facing step (baldwin lomax model). At inlet I imposed a uniform velocity and temperature. 20 stepheights from the corner to develop the boundary layer. Reynolds is 37000 based on stepheight. At the outlet I used the rieman invariant boundary condition, (Rn=-abs(Vn)+2c/gamma-1). However when convergence is nearly reached, it explodes. Could it be that the two boundary conditions are not compatible?
Greetings,
Jan
Old   August 19, 1999, 12:15
John C. Chien
(1). I don't have the time to worry about whether the condition is properly coded. I am assuming that you are using the transient approach. (2). The suggestion is: find out the location where the calculation diverges. Plot the flow field ( or xy plot) before it diverges. Study the flow field evolution before it diverges. (3) In this way ,you can narrow down the location and the cause of the problem. You can also try a uniform mesh (uniform in x, uniform in y, separately) to elminate the mesh related causes. It is also important to mention whether it is transient formulation, or pressure based, or density based. The method of solution is also important along with the initial guess, the number of iteration at the time the solution diverges.
My DES result about BFS! aladdincham Main CFD Forum 0 July 20, 2011 07:44
solving BFS with rhoTurbFoam in OpenFOAM 1.5 kiran OpenFOAM Running, Solving & CFD 0 June 11, 2010 00:36
Non-Newtonian Flow: Power law (2D BFS) hellouch FLUENT 3 April 21, 2009 03:03
Setup for laminar backward facing step (bfs) quarkz Main CFD Forum 13 September 30, 2005 09:51
BFS: steady? Jan Ramboer Main CFD Forum 1 September 9, 1999 14:04
