non-orthogonal corrections for convective terms
Old   June 12, 2013, 12:18
Default non-orthogonal corrections for convective terms
Jonathan is on a distinguished road
Hi everyone,
i was just wondering whether someone could explain why there seems in general for unstructured meshes, no mention / worry about non-orthogonal corrections to the face flux values for convection terms as there are for the diffusion terms .
for example:
in OpenFoam, there are specific correction schemes to deal with mesh non-orthogonality when discretizing the laplacian terms in the N-S equations, but nothing for the convective term.
surely, since both calculate face flux values as part of the FV discretization process, there must be an effect just as much on the convective terms due to mesh non-orthogonality as with the diffusion (laplacian) term.
many thanks, and regards
jonathan
Jonathan is offline   Reply With Quote
Old   June 12, 2013, 12:36
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Jonathan View Post
Hi everyone,
for example:
jonathan
I am not sure if I understand your question... however, in a FV formulation the diffusive flux requires the normal component of a gradient on each surface, the convective flux does not.
FMDenaro is offline   Reply With Quote
Old   June 12, 2013, 12:55
Default thanks
hi Phillipo
thanks very much for your answer - i think you understand me!
ok, so if i understand you correctly, its only the gradient vector at the face which needs to be parallel to the face normal vector, not the flux itself?
many thanks regards
jon
Implicit treatment of advection terms and pressure correction nikosb Main CFD Forum 0 January 17, 2010 16:07
Using source terms jsm Main CFD Forum 4 August 20, 2009 06:44
Question in definition of terms in solve titio OpenFOAM Running, Solving & CFD 0 March 19, 2009 16:02
Circular Cylinder at low Reynold number mesh and non orthogonal corrections kassiotis OpenFOAM Running, Solving & CFD 6 May 15, 2008 06:07
K-Epsilon model? Brindaban Ghosh Main CFD Forum 2 June 24, 2000 04:22
