May 8, 2013, 03:51 |
Basic Fluid mechanics
Hello everyone
I have very bad knowldege in fluid mechanics..Explain me about Newtanion fluid.I need the derivation for the topic called "CONSTITUTIVE EQUATIONS FOR NEWTONION FLUID"(or viscous fluid)..some 6 equations like towxx=2M(mu)(du/dx) similar for yy and zz include xy,yz and zx.. explain me pls |
May 29, 2013, 05:01 |
Rami Ben-Zvi
Rep Power: 17 |
Hi Sayee Chandrasekara Mouli,
Newtonian fluid means there is a linear relation between the stress and the strain-rate tensors (analogous to elasticity, where the stress is proportional to the strain). This is written (in tensor notation) as Sik = -p * Iik +lambda * Emm * Iik + 2*mu * Eik where Sik is the stress, Eik is the strain-rate, p is the pressure, Iik is the identity tensor, mu is the viscosity, muv is the bulk viscosity (usually assumed 0, i.e., Stokesw assumption) and lambda=muv - 2/3* mu is similar to Lame constant in elasticity. The viscous stress, Tik, is defined as Tik = Sik + p * Iik The stain-rate is related to the velocity vector Ui through 2*Eik = Ui,k + Uk,i From these relations you can easily derive the relations you asked about. Rami
equations, newtanion fluid |
basic fluid flow problem - is there a way to switch pressure to a flow rate in analyt | vlnikolic | Main CFD Forum | 3 | September 16, 2016 04:07 |
How to choose the mean diameter value for dispersed fluid? | creddy_trddc | CFX | 1 | October 30, 2011 04:30 |
Study fluid mechanics in Russia | neo | Main CFD Forum | 4 | September 17, 2006 06:09 |
Environmental fluid mechanics | Donald D. Gray | Main CFD Forum | 2 | September 25, 1998 15:54 |
