force frequency
Old   July 24, 2006, 08:49
Default force frequency
kevin
hi,all
i want to know that why the frequency of Drag coefficient is twice over that of lift coefficient?
i checked some books and papers, but got no answer, would you please give me a hand?
thanx in advance
kevin
Old   July 24, 2006, 12:21
Default Re: force frequency
Bob
If you consider a cylinder undergoing vortex shedding then the drag coefficient is the same if vortex is at its maximum height or at its minimum height wrt the cylinder. On the other hand, the lift has opposite signs for these two vortex positions. So, over one shedding period the lift cycles through once while the drag cycles through twice.
Old   July 25, 2006, 04:58
kevin
thanx a lot, Bob.
i knew this that "the drag coefficient is the same if vortex is at its maximum height or at its minimum height wrt the cylinder. On the other hand, the lift has opposite signs for these two vortex positions", but if f_Cd is 2^n*f_Cl, the phenomenon you said also seems reasionable, then, maybe Cd arrives its mininum as vortex at the mean height(on the axis of the cylinder)?
# Cd is coefficient of drag and Cl of lift.
please give me more details.
Old   July 28, 2006, 17:06
turb
It is the same thing as compare sin(t) with (sin(t))^2.
The square of the sine oscillates twice as fast as the pure sine.
Cheers
Force can not converge colopolo CFX 13 October 4, 2011 22:03
User-defined force transfer across FSI interface vivekcfd CFX 7 March 10, 2010 20:43
Urgently Need the code of Lift force and VM force Kai Yan Main CFD Forum 0 July 16, 2008 07:07
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 10:25
pressure force and viscous force CFD FLUENT 0 March 7, 2006 01:03
