Error in Time Calculation in transition mode
Old   August 22, 2006, 09:40
Default Error in Time Calculation in transition mode
Morteza
Hi Guys,
I have a weird error in my code. When my code is marching in time in transition mode, somewhere between T_0 and T_END an error in claculation of time is occured. As an example, for dt=0.1, at Time=5.9 the value of Time in next time step is calculated as Time=5.9999999999 instead of 6.0 or for dt=0.2, it happens in Time=23.2 and Time is 23.3999999 instead of 23.4. I used Double Precision for dt and Time variables but still I have this problem. I appreciate to receive your advise to fix this issue.
Thanks Morteza
Old   August 23, 2006, 06:51
Default Re: Error in Time Calculation in transition mode
Mani
How do you advance the time: Do you keep adding dt to the previous time, or do you multiply dt with an integer number of time steps?
Old   August 23, 2006, 07:21
Morteza
Hi Mani,
It is just adding dt to previous time,
Thanks Morteza
Old   August 23, 2006, 07:54
Morteza
Hi Mani,
Thanks Morteza
Old   August 24, 2006, 07:16
Mani
This will be inherently inaccurate as you keep accumulating round-off errors. The general advice is to use an integer as increment (number of time steps) and obtain the current time by multiplication of that integer with dt.
calculation of time step aamer Main CFD Forum 8 December 8, 2010 03:26
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
Warning 097- AB Siemens 6 November 15, 2004 04:41
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
