R-134a Cp Zero pressure coefficients
Old   August 4, 2013, 12:28
Thumbs down R-134a Cp Zero pressure coefficients
Gato Lopez
enuano is on a distinguished road
Hello!
I just wanted to know if someone already simulated R-134a as a real gas in ANSYS CFX-Pre and could tell me the coefficients he/she used in order to set the heat capacity at constant pressure Cp, because mine are not working; When iterating, some variables fall out of range and the simulation does not converge.
Thank you very much!
enuano is offline   Reply With Quote
r-134a, realgas, zero pressure gradient
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 12:41
Setup/monitor points of pressure and force coefficients siw CFX 3 October 22, 2010 06:07
Specifying Wind Pressure Coefficients NK FLUENT 0 January 30, 2009 07:32
About the pressure coefficients Wong Phoenics 3 June 11, 2003 16:15
pressure. lift and drag coefficients waqar mahboob Main CFD Forum 0 July 25, 1998 03:34
