NF calculation in NASA-VOF2D
Old   September 11, 2006, 22:02
Default NF calculation in NASA-VOF2D
Fan
Is anyone familiar with the PETACAL subroutine of NASA-VOF2D? In the codes, NF values are claculated based on two variables: PFX and PFY. They are said to be the partial derivatives of F in X and Y directions. But I don't understand how they derived those formulas for surface slopes. If the codes are extended to 3D, how to express PFX, PFY and PFZ? Thank you!
Old   September 12, 2006, 01:28
Default Re: NF calculation in NASA-VOF2D
rt
In fact you need to calculate the slope (normal of surface) of interface, then based on principal component of normal select one NF, e.g. if normal vector is: (3., 1, 2) principal direction is positive x-direction and NF is 1 (i don't mention this in nasa code, probably for this nf is 1).
so you must calculate normal: normal is derivative of F (volume fraction) field: in simple way you can sum all 9 neighbour of each side of cell and e.g. for x-component calculate difference of this summation of left and right face over DELT_x. better way is using waighted averaging.
e.g. (in fortran, )
c normal vector: mx,my,mz; c loca(i-1,j-1,k-1)=(i,j,k) in 3d array
mm1 = F(loca(i-1,j-1,k-1))+F(loca(i-1,j-1,k+1))
% +F(loca(i-1,j+1,k-1))
% +F(loca(i-1,j+1,k+1))+2.0d0*(F(loca(i-1,j-1,k))
% +F(loca(i-1,j+1,k))
% +F(loca(i-1,j,k-1))+F(loca(i-1,j,k+1)))
% +4.0d0*F(loca(i-1,j,k))
mm2 = F(loca(i+1,j-1,k-1))+F(loca(i+1,j-1,k+1))
% +F(loca(i+1,j+1,k-1))
% +F(loca(i+1,j+1,k+1))+2.0d0*(F(loca(i+1,j-1,k))
% +F(loca(i+1,j+1,k))
% +F(loca(i+1,j,k-1))+F(loca(i+1,j,k+1)))
% +4.0d0*F(loca(i+1,j,k))
mx = mm1 - mm2
% +F(loca(i+1,j-1,k-1))
% +F(loca(i+1,j-1,k+1))+2.0d0*(F(loca(i-1,j-1,k))
% +F(loca(i+1,j-1,k))
% +F(loca(i,j-1,k-1))+F(loca(i,j-1,k+1)))
% +4.0d0*F(loca(i,j-1,k))
mm2 = F(loca(i-1,j+1,k-1))+F(loca(i-1,j+1,k+1))
% +F(loca(i+1,j+1,k+1))+2.0d0*(F(loca(i-1,j+1,k))
% +F(loca(i,j+1,k-1))+F(loca(i,j+1,k+1)))
% +4.0d0*F(loca(i,j+1,k))
my = mm1 - mm2
mm1 = F(loca(i-1,j-1,k-1))+F(loca(i-1,j+1,k-1))
% +F(loca(i+1,j+1,k-1))+2.0d0*(F(loca(i-1,j,k-1))
% +F(loca(i,j-1,k-1))+F(loca(i,j+1,k-1)))
% +4.0d0*F(loca(i,j,k-1))
mm2 = F(loca(i-1,j-1,k+1))+F(loca(i-1,j+1,k+1))
% +F(loca(i+1,j+1,k+1))+2.0d0*(F(loca(i-1,j,k+1))
% +F(loca(i+1,j,k+1))
% +F(loca(i,j-1,k+1))+F(loca(i,j+1,k+1)))
% +4.0d0*F(loca(i,j,k+1))
mz = mm1 - mm2
after calculating (mx, my, mz) compare component of select appropriate direction then NF, if three component is nearly equal you can set NF as 0 or use weighted averaging instead using one interpolating cell.
Old   September 12, 2006, 18:06
Fan
rt: Thank you very much for your help! I still have some questions with your algorithm. 1. Why are the weights of F(loca(i-1,j-1,k)etc. greater than those of other neighboring cells? I understand the weight of the center cell is greater. But I don't understand why F(loca(i-1,j-1,k)etc are special. 2. What is the meaning of "local(x,y,z)"? Does F(local(x,y,z)) means F(x,y,z)?
Thank you!
Old   September 13, 2006, 02:12
rt
consider 9 neighbor of one face (e.g. left face) i divide them to 3 types:
1) first degree weight=4 shared with one face (e.g. i-1,j,k) 2) second degree weight=2 shared with one edge (e.g. i-1,j-1,k) 3) third degree weight=1 shared with one point (e.g. i-1,j-1,k-1)
>>Does F(local(x,y,z)) means F(x,y,z)? yes for better performance i vectorize array (convert 3d array to 1d) and Loca find virtual position (i,j,k) in 1D array.
Old   September 13, 2006, 11:05
Fan
I see. Thank you very much!
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
Warning 097- AB Siemens 6 November 15, 2004 04:41
NASA VOF2D code Wen Long Main CFD Forum 1 December 20, 2001 03:03
