which one is faster
Like Tree1Likes
  • 1 Post By FMDenaro
Old   August 14, 2013, 07:56
Default which one is faster
morteza08's Avatar
Morteza
morteza08 is on a distinguished road
Hi
I am doing a project in Compaq fortran.
Is it better to build an exe file and run it instead of copiling the code for having faster performance? of there is no difference between them?
Please give me a scientifically-approved response
morteza08 is offline   Reply With Quote
Old   August 14, 2013, 08:07
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by morteza08 View Post
Hi
your question is not clear to me ... what do you mean for "instead of copiling the code for having faster performance"
Compaq Fortran is a very old compiler (migrated to Intel), better performances can be now obtained by modern compiler.
However, for having better performance is better to create the exe file, using all the optimization procedures (O5, loop unroll, etc.) after you are sure that no bugs are (presumibly) present. The problem is that your exe file is optimized for old architectures and can run slowly on the modern multi-core
morteza08 likes this.
FMDenaro is online now   Reply With Quote
Old   August 14, 2013, 09:59
morteza08's Avatar
Morteza
Thank you dear friend.
I mean for my code, I can build an exe file and run it on any other PC that fortran may not be installed. and also I can go to RUN menu and click on run.
For one case, in which case the speed of running the code is faster without any attention to optimizations settings. for the same code on the same PC.
Old   August 18, 2013, 10:09
leflix is on a distinguished road
Apparently you work under Windows as you have an exe file. First migrate under Linux (whatever the distribution) Linux has a better managment of RAM memory than Windows. Then as Filippo suggested it Intel compiler is very efficient. I have compiled the same source code under force 2 compiler/windows and Intel compiler/Linux and I obtained 30% of decrease of the CPU time with Intel/Linux.
leflix is offline   Reply With Quote
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
Speed of Convergence faster with smaller time step Torque_Converter CFX 1 May 15, 2012 19:22
Explicit converging faster compared to implicit harish_0689@ Main CFD Forum 5 January 23, 2012 07:00
Flamelet gives faster chemistry than ED-model champshof FLUENT 0 November 30, 2011 10:01
Is there any faster way to open a def file more than 100Mb? CFD_D_BOY CFX 5 October 9, 2011 05:06
