August 15, 2013, 05:29 |
Absence of Table generation (real gas)
Gato Lopez
Rep Power: 12 |
Hi there!
I'm trying to simulate refrigerant R-245fa in ANSYS CFX as a real gas with the Peng Robinson model. I tried with the default temperature and absolute pressure limits for the table generation, but when iterating, the calculations fell out of the limits and it did not converge. I just tried not activating the table generation limits. A warning appeared, which I just ignored... The solver converged and found a result. The results are not very satisfying, but I think it should be a problem with the Cp coefficients. My question is: Is it Ok not to set limits for the table generation and ignore the warning? Thank you very much |
pengrobinson, r245fa, realgas, tablegeneration |
view factor | yoollooz | Fluent UDF and Scheme Programming | 0 | March 1, 2013 00:44 |
reference pressure and relative pressure in CFX and real gas setting | nuimlabib | Main CFD Forum | 0 | October 12, 2010 20:55 |
Sod shock tube problem with real gas effects | ganesh | Main CFD Forum | 0 | October 17, 2006 01:22 |
about the real gas in Numeca | redboy | Fidelity CFD | 2 | March 4, 2003 07:57 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
