August 21, 2013, 10:52 |
Simple vs piso
Dongyue Li
Hi guys,
Im working on the reseach regarding the difference between steady SIMPLE and steady PISO. Its tough to write in this forum. So see the image pls. My reference is H K Versteeg's book: An introduction to ....... As we know, in PISO we have a second corrector step which make it different with SIMPLE, but my confusion is “why is this second corrector step instrumental to the solving?” In H K’s book, I make a conclusion(IF I WAS WRONG, CORRECT ME PLEASE): |
August 21, 2013, 11:25 |
Ren/Xingyue
The corrective pressure computed from the SIMPLE method is not the real pressure, so the second step is to make sure divergence of the corrected velocity field is zero. That is why the projection method is more popular than the SIMPLE method in the computation of unsteady flows.
August 21, 2013, 20:05 |
#3 | ||
Dongyue Li
Am I right? So, as you had said, both of the first step in SIMPLE and the two steps in PISO are making sure the velocity field divergence free, Why does PISO make it divergence free twice? If I was wrong above, correct me, Thanks in advance. |
August 21, 2013, 21:42 |
Dongyue Li
This will make it clearer.
August 22, 2013, 03:22 |
#5 | |
Ren/Xingyue
In SIMPLE method, the approximated velocity is computed implicitly but the corrective pressure is computed explicitly. That can't be coupled with one iterative step. |
pressure equation in PISO or SIMPLE algorithm | mechy | OpenFOAM | 2 | July 22, 2013 14:17 |
Continuity. Stop critertion of PISO and SIMPLE in OpenFOAM solvers. | idrama | OpenFOAM | 4 | September 21, 2010 03:26 |
SIMPLE and PISO | Aditya | Main CFD Forum | 5 | April 1, 2006 18:52 |
diffrence beetwen SIMPLE and PISO | grzes | FLUENT | 0 | January 29, 2006 05:57 |
PISO vs. SIMPLE | benedikt flurl | Main CFD Forum | 2 | April 14, 2005 06:54 |
