How to write a CFD code for cylinder wake?
Like Tree3Likes
  • 2 Post By Alex C.
  • 1 Post By leflix
Old   August 30, 2013, 04:54
Default How to write a CFD code for cylinder wake?
shubiaohewan is on a distinguished road
I want to write a code for the wake flow behind a cylinder. Where should I start? (Of course, the cylinder.) I knew I should use the immersed boundary method. Do you have a tutorial code or reference where I can learn? Thanks.
Shu
shubiaohewan is offline   Reply With Quote
Old   August 30, 2013, 08:23
Alex C. is on a distinguished road
It all depends on your previous experience with CFD codes. Asssuming you are new to the field, I would greatly suggest you to work the 2D case first. Going with the simplest methods at first, you could try a finite difference. You could also start with a finite volume (which will lead you further then finite difference) using Versteeg & Malalasekera Introduction book.
Also, unless you have strong experience, forget about turbulence modelling until you have strong results for inviscid and laminar flow.
lakeat and Bou Med like this.
Alex C. is offline   Reply With Quote
Old   August 30, 2013, 20:24
leflix is on a distinguished road
Originally Posted by shubiaohewan View Post
Shu
Immersed boundary (direct forcing) for your case seems indeed the simplest way to tackle this problem. It gives good results. Use finite difference too for simplicity of implementation.
Bou Med likes this.
leflix is offline   Reply With Quote
Old   August 31, 2013, 05:35
Thank you both, Alex and leflix. I have some experience with FD, but new to immersed boundary method. I don't know where I should start. Could you recommend a textbook on IB method with simple hand-on code? Thanks.
Shu
Old   August 31, 2013, 07:10
T I don't know where I should start. Could you recommend a textbook on IB method with simple hand-on code? Thanks.
Shu
I don't have bibliography on mind right now,but you should find many papers in Journal for Computational Physics related to this topic.
Many different methods exist but the most simple to my mind is the direct forcing method where you ensure the no slip boundary condition on the surface of the cyinder as well as on all nodes inside the cylinder.
Old   January 3, 2017, 03:29
Bouanani Mohammed
Bou Med is on a distinguished road
Send a message via Skype™ to Bou Med
Hi
Do you think that the ghost cell methode is a right choice to simulate a rigid cylinder inside a fluid ?
Thank you
Bou Med is offline   Reply With Quote
Old   January 3, 2017, 10:37
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Bou Med View Post
Hi
Thank you
It can give you acceptable results for laminar flows but in case of turbulence you need a very fine grid. You can find many papers for the IB method in several journals
FMDenaro is online now   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
CFD Salary CFD Main CFD Forum 17 January 3, 2017 17:09
general ARCHITECTURAL structure of the code of a CFD code mecobio Main CFD Forum 0 August 12, 2013 08:04
Give me some advice CFD in Fortran code or Matlab code. tringuyenttt Main CFD Forum 4 May 29, 2013 08:32
Debugging Unsteady 2-D Panel Method Code: Wake Modeling RajeshAero Main CFD Forum 5 November 10, 2011 05:48
