September 8, 2013, 09:54 |
How to obtain these S809 experiment points?
Rep Power: 12 |
Hi all.
Does anybody have or know how to get these S809 experimental results(coordinates of the discrete points) in the literature, so that I can import those points and compare them with my calculated results? Can't find it elsewhrere. Please see the attachment. Thank you for your help. |
September 8, 2013, 13:35 |
cfdnewbie
Rep Power: 20 |
Just use a digitalization software and extract the points. Try this one for example: http://sourceforge.net/projects/digi...digitizer-5.1/
September 8, 2013, 22:13 |
Rep Power: 12 |
That's so knid of you, it's so nice.
I'm the real "cfdnewbie", thank you again. |
[snappyHexMesh] .STL: non-closed manifold surface | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 32 | November 25, 2016 03:15 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? | ANT | ANSYS Meshing & Geometry | 2 | July 23, 2012 15:25 |
How to obtain the index of all the points that belong to a particular patch | mathieu | OpenFOAM Running, Solving & CFD | 2 | October 15, 2008 09:16 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
