multicomponet flow vs.Homegeneous multiphase flow
Old   September 30, 2006, 00:36
Default multicomponet flow vs.Homegeneous multiphase flow
klarke
hi,all
what's the difference between multicomponet flow and Homegeneous multiphase flow?
Old   October 1, 2006, 23:28
Default Re: multicomponet flow vs.Homegeneous multiphase f
Junseok Kim
I guess you may want to know that, for example multicomponent - water and oil multiphase - water and vapor
Old   October 2, 2006, 08:13
chi
hi klarke,
I suppose you refer to homogeneous multi-component flow instead of homogeneous multiphase flow, and multi-phase flow instead of multicomponent flow. (correct me if i'm wrong).
Homogeneous multi-component flow is a type of flow we consider by assuming that all participating species making up the mixture are mixed at the molecular scale and they all share the same velocity and pressure, hence also temperature. When using this assumption, convection and diffusion are the main modes of mass transfer.
On the other hand, multi-phase flow is a more complex case, since the various species are mixed at larger scales and each phase has its own solution field.
hope that answers.
chi
Old   October 2, 2006, 22:43
Angen
In fact, water and oil can be either single-phase multicomponent or two-phase multicomponent (e.g. water with small oil droplets) depending on their mutual miscibility.
Angen
Old   October 7, 2006, 20:10
klarke
thanks,all
I really mean is that you can find multicomponent flow model and homogeneous multiphase flow model in cfx, so i 'd like to know what's difference and related examples
Old   October 10, 2006, 22:10
Angen
Ask CFX support or in CFX Forum.
Angen
Multiphase flow! Amer FLUENT 2 May 16, 2012 15:57
multiphase flow, aeration Ellie CFX 3 January 15, 2009 17:33
Realizable k-epsilon eqns for multiphase flow Rana FLUENT 0 December 8, 2006 13:46
correct visualization of multiphase flow jemteo CFX 0 April 5, 2006 06:27
multiphase flow Shane Gillis FLUENT 10 August 28, 2000 19:12
