Turbulent kinetic energy for accelerating fluid (nozzle)
Old   September 24, 2013, 08:17
Default Turbulent kinetic energy for accelerating fluid (nozzle)
hekseli
heksel8i is on a distinguished road
Hey!
Assuming a high pressure chamber with a converging or converging-diverging nozzle, the fluid is accelerating on its way out. While determining the turbulence boundary conditions for the nozzle inlet, a question arises which mean velocity should be used in kinetic energy equation k=(3/2)(UI)^2. Intensity is probably low, around 1%?
Personally I guess after some simple simulations that mean velocity between inlet and throat could be appropriate. (v_throat - v_inlet)/2.
heksel8i is offline   Reply With Quote
Old   September 30, 2013, 08:26
hekseli
It is also interesting to calculate the parameter values with the initial velocity in a chamber, which is really really slow compared to the throat velocities. Pressure and velocity field results do not change so much but of course turbulence quantities change drastically...
Any ideas?
question about turbulent kinetic energy junker4236 Main CFD Forum 19 April 19, 2017 04:46
turbulent kinetic energy is not zero at the wall yogi06_sati FLUENT 7 April 28, 2014 11:03
turbulent kinetic energy in TGV case baraban55 Main CFD Forum 6 March 12, 2012 16:12
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 13:22
