from c to fortran
Old   November 5, 2013, 15:09
Default from c to fortran
RAWNAK.h
Rawnak is on a distinguished road
please I need a help to understand this c-code (two phase flow), which I try to write it using fortran
for( subs=0; subs<NUM_FLUID_COMPONENTS; subs++)
for( j=0; j<LY; j++)
for( i=0; i<LX; i++)
rhoij[subs] = 0.;
u_xij[subs] = 0.;
u_yij[subs] = 0.;
if( !is_solid_node[j][i]) {
for( a=0; a<9; a++) {
rhoij[subs] += ftemp_ij[a];
u_xij[subs] += ex[a]*ftemp_ij[a];
u_yij[subs] += ey[a]*ftemp_ij[a]; } }
well here the code in fortran:
do l=1,2
do j=0,m
do i=0,n
rho(i,j,l)=0.0
u(i,j,l)=0.0
v(i,j,l)=0.0
do k=0,8
rho(i,j,l)=rho(i,j,l)+f(k,i,j,l)
u(i,j,l)=u(i,j,l)+f(k,i,j,l)*cx(k)
u(i,j,l)=v(i,j,l)+f(k,i,j,l)*cy(k)
end do
enddo
end do
end do
the thing that I don't understant how to write if( !is_solid_node[j][i])
Thank you
Rawnak is offline   Reply With Quote
Old   November 5, 2013, 15:29
cfdnewbie
cfdnewbie is on a distinguished road
It is a NOT IF, so the way in FORTRAN to do this is : IF (.NOT.somelogical) THEN
Cheers
cfdnewbie is offline   Reply With Quote
Old   November 5, 2013, 15:40
RAWNAK.h
Thank you for your reply,
Well, here we have two fluids sub=0 and 1
why we put if not solid, what do they mean?
Old   November 5, 2013, 15:44
cfdnewbie
That is something only you can answer, as you are the one who works with the codes... from the snippet you posted, there is no way to understand the whole issue....
You first should make sure you understand the equations, assumptions and schemes that are involved fully before you try to rewrite the program. without understanding what is going on, there's no chance!
Old   November 5, 2013, 15:54
RAWNAK.h
You're totally right, thanks alot
Old   November 6, 2013, 14:47
Default question
RAWNAK.h
what does i++ mean in the following sentence
i=0; i<LX; i++
and what does this mean
( i<LX-1)?( i+1) 0 );
because I know fortran and not c programming
Thanks
Old   November 6, 2013, 16:28
cfdnewbie
The first one does just mean i=i+1. I can't read the second one due to the smiley. You should consult a C manual for your questions or use google, as they can be answered very easily that way.
Cheers,
Fortran Compiler-CFX12.1 Araz CFX 13 March 27, 2017 05:37
Using Fortran with CFX: How to connect Fortran to CFX? l.te CFX 0 October 21, 2012 11:42
Intrinsic Procedure 'ISNAN' in GNU FORTRAN 77 hawk Main CFD Forum 1 April 12, 2005 22:13
visual fortran Monica Main CFD Forum 1 August 28, 2004 20:45
Fortran77 or Fortran 90 Swapnil CFX 2 November 26, 2002 15:16
