November 20, 2013, 02:29 |
Can this simulation be created using CFD?
Rep Power: 12 |
I want to create a simulation in which the viscosity of the material varies with time and temperature, by this I mean if you place this material on a plate at constant temperature,over time its viscosity will change. The viscosity of the material will initial decrease and then after time t it will start increasing at an exponential rate.
I would like to simulate this for varying geometries, temperatures and materials. Is this even possible to simulate using CFD or does it require a different simulation type? If possible using CFD could anyone give me any guidance on what I need to understand before attempting something like this? |
November 20, 2013, 04:36 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
November 20, 2013, 08:05 |
Rep Power: 12 |
I can obtain rehometer readings which generate a graph which shows the torque versus time readings for a set temperature, is this what would be required? If not I can obtain further information.
November 20, 2013, 08:39 |
#4 | |
Rep Power: 71 |
are you able to create a database and use continuous values by interpolation of discrete datas? If so, you can do CFD simulation using an access to such datas to compute viscosity as function of time and temperature |
November 20, 2013, 15:40 |
Rep Power: 12 |
I can obtain the values to create this database however, what would I use to create this, would it be something that is created within the CFD software used or an external software package?
Is this considered a non-isothermal flow simulation? Could this be simulated using some sort of standard solidification model? The viscosity variations occur because of a reaction within the material, therefore would this require some form of a reaction solver or should the database values cover this? |
November 20, 2013, 17:00 |
#6 | |
Rep Power: 71 |
Consider that mu=mu(Theta,t) is required in the momentum and energy equation; if you can prescribe it by some mathematical law or experimental datas, you can set as boundary condition. Otherwise, you should solve time-by-time the reaction equation that governs its evolution, coupling that to the flow equations. |
November 20, 2013, 17:23 |
Rep Power: 12 |
The material I am working with is rubber and the process is known as curing, the test results obtained which the mathematical model will be generated from apply to a simple block geometry of a small volume. For larger geometries the time required for this solidification (curing of rubber) is much longer, will using mu=mu(Theta,t) take this into account or will I have to use the time-by-time reaction equation?
Is real time CFD simulation possible | yedla | Main CFD Forum | 5 | March 28, 2016 09:56 |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
CFD Modelling & Simulation of Boiler Flue Fas Flow | jaspernare | CFD Freelancers | 7 | July 25, 2013 02:57 |
CFD simulation of Progressive cavity Pump | MrinalKR | CFX | 4 | September 13, 2012 07:36 |
Solidification CFD simulation | Min-Hua Wang | FLUENT | 0 | February 28, 2001 17:40 |
