k-epsilon
Old   November 29, 2006, 07:28
Default k-epsilon
flozzermeister
hello, I was wondering if someone could tell me why the K-epsilon model is the most broadly used model for turbulence ?
any downsides, upsides ?
thanks in advance
Old   November 29, 2006, 22:31
Default Re: k-epsilon
M.SURESH KUMAR
it's a asimple one, very easy to solve, mostly validated by various researchers more or less all kind sof applications. Moreover, it resembles real situations to the good extent.
Old   December 5, 2006, 03:48
satya
hi i want to compressible flow through nozzle, my inlet pressure and temperatures are 125 atm and 3600 k. which model( turbulence) i have to select for modelling this? i want to calulate the temperature of gas at the exit of the nozzle, and also machnumber at exit? can any body help me in this regard. thanks in advance.
Old   December 5, 2006, 04:16
flozzermeister
well, the k-epsilon model is the one used by almost all cfd codes, so anyways you should use that one. I think your gas is gonna be under-expanded and sonic, so you must work out the equivalent diameter + concentration of gas already mixed with air to model the leak.
Old   December 5, 2006, 04:18
flozzermeister
3600 Kelvin ?
Old   December 5, 2006, 06:12
satya
ya,inlet temperature at inlet of nozzle is 3600 k and pressure at inlet is 125 atm. i modelled the geometry of the nozzle as axi-symmetric and try to obtain the initial solution using k-epsilon model, but initially itself divergence is coming the error is coming as divergence detected in AMG solver. when i initialize the solution and ask it to compute from inlet , the message coming in solver pannel is PRESSURE IS LIMITED TO 5E6 IN ALL CELLS. but my actual pressure is only 125 atm, why this message is coming , do u know the answer? waiting for your reply
Old   December 5, 2006, 06:47
flozzermeister
can you give me the molar mass of your gas ?
Old   December 5, 2006, 06:52
flozzermeister
and your nozzle diameter please, thanks
Old   December 5, 2006, 22:54
satya
hi my nozzle diameter at inlet is 124 mm and at throat is 73 mm, divergent i,e exit is 145 mm. the molar mass of the gas ( molecular weight of gas at inlet is 23.291 kg/kmol, at exit is 24.601 kg/kmol) density at inlet is 9.4196 kg/m3, at outlet is 6.6765 kg/m3. ok
thanks already for reply.
Old   December 6, 2006, 05:49
flozzermeister
For a 145 mm diameter, a molar mass of 24.601 Kg/Kmol. my program gives : gas exits at 822 m/s (sonic release then) with a massflow of 312 kg/sec at 1630 K temperature.
If you want to model it, then you would have to use a pseudo diameter cause it's under expanded. programm gives an equivalent diameter of 1.5 metres.
If you use that pseudo diameter,the gas has already mixed with air so you need the right concentration.
for your divergence problem, check the boundary conditions but you should post a new thread cause i am not an expert at all.
good luck.
Old   December 13, 2006, 02:37
  #11
satya
hi thanks for your reply, but the temperature which you have given by your program is at exit only. but same configuration may exit is at 2600 k. how can it be possible. thanks already for reply
Old   December 13, 2006, 03:10
  #12
flozzermeister
I am not sure i know what you meant here. please be more concise.
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
How to get reference to k and epsilon in the epsEqn and kEqn cfd_explorer OpenFOAM Programming & Development 0 March 10, 2011 10:16
How to get reference to k and epsilon in the epsEqn and kEqn cfd_explorer OpenFOAM 0 March 10, 2011 09:58
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
