Difference between GMRES and TDMA
Old   January 3, 2007, 14:27
Default Difference between GMRES and TDMA
Mehdi
I am going to change my solver from TDMA to GMRES. Does anyone know which one is faster. I do not want to waiste my time by changing my solver.
Is there any big difference in CPU time if I use GMRES?
Regards,
Old   January 4, 2007, 10:56
Default Re: Difference between GMRES and TDMA
raju
GMRES by itself is very inefficient (as far as my experience goes). It needs a good preconditioner. So you must have some knowledge about preconditioners.
Old   January 4, 2007, 11:56
Praveen. C
If you are using TMDA, I guess your matrix is triangular. TMDA is the best scheme in this case.
Old   January 5, 2007, 10:45
Luca Cavagna
Yes I agree with raju and praveen. If you have a tridiagonal matrix keep on using the TDMA which has been specifically developed. As raju said GMRES is not the solution to every problem! You need a good preconditioner to reduce the number of iteration and you may run out of memory is you have many degrees of freedom. Luca
GMRES Mehdi Main CFD Forum 3 December 31, 2006 11:03
