December 16, 2013, 05:09 |
Ideal gas v.s. Real gas for wing simulation
Meimei Wang
Rep Power: 15 |
Ideal gas properties are different from the real gas properties. I noticed that when people simulation airfoil (like the Fluent tutorial), they always choose ideal gas rather than real gas. May I ask why? That won't introduce large error? Why don't they use the real gas?
Best regards, Meimei |
December 16, 2013, 11:39 |
Rep Power: 18 |
The ideal gas model is a very accurate model over a fairly large range of temperatures and for pressures that are not too high. The definition of "too high" is somewhat fuzzy, but most good thermodynamics books will provide background on when the ideal gas equation of state is not sufficient and should be replaced by a better model, say the van der Waals EOS. One other thing to keep in mind s the difference between an ideal gas model (specific heats are functions of temperature), and the perfect gas model (where the specific heats are constant.)
Parallel User Defined Real Gas Model | aeroman | FLUENT | 4 | July 1, 2015 06:09 |
view factor | yoollooz | Fluent UDF and Scheme Programming | 0 | March 1, 2013 00:44 |
UDF for Turbulent Viscosity | Lourival | Fluent UDF and Scheme Programming | 3 | October 13, 2012 03:09 |
UDF error - FLUENT received fatal signal (ACCESS_VIOLATION) | Eliasjal | Fluent UDF and Scheme Programming | 1 | March 7, 2012 11:11 |
Real Gas Mixture With Reactions | Jake Cannon | Main CFD Forum | 0 | January 16, 2007 11:46 |
