3-d CFd analysis of labyrinth seals
Old   September 20, 1999, 12:22
Default 3-d CFd analysis of labyrinth seals
murali mohan
I am getting troubles in doing the cfd anaysis of grooved labyrinth seal using FLUENT,pls any body who are working on this field help me
Old   September 24, 1999, 14:17
Default Re: 3-d CFd analysis of labyrinth seals
Zhenhua Xiao
Recently I performed a 2-D CFD analysis of an industrial Labyrinth seal which has grooves on the rotor side. Fluent 5 did a great job predicting the pressure drop and windage heat-up through the Laby seal. The predicted pressure drop is within 1.3% and the temperaure rise is within 1% compared with test data. I am not sure what kind of problems you have when you try to simulate the seal. Please be specific about the problems and I will see if I can be any help.
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
CFD software capable of modal analysis? Jim-gineer Main CFD Forum 4 January 14, 2010 09:29
FDM vs FVM vs FEM in CFD analysis ck5285 FLOW-3D 1 September 1, 2009 10:51
CFD Analysis of pump remith CFX 7 October 6, 2008 07:57
ASME CFD Symposium Chris Kleijn Main CFD Forum 0 August 22, 2001 06:41
