Fluent-OpenFoam pipe flow comparison
Like Tree1Likes
  • 1 Post By RodriguezFatz
Old   January 7, 2014, 03:28
Default Fluent-OpenFoam pipe flow comparison
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Dear all,
I am trying to get the same results in Fluent and OpenFoam for a simple pipe flow (periodic). Unfortunately, the results are quite different and I am wondering if that is just normal for two solvers or if I am doing something wrong.
My settings are: DN25 pipe, standard k-e-model, mean velocity = 7 m/s, water, y+=1. I use "enhanced wall treatment" in Fluent and lowRe-wall functions in OpenFoam.
These are some results:
My feeling says something is wrong...
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   January 7, 2014, 07:26
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
which Turbulence Model did you use in OpenFOAM?
If it can help you: http://www.cfd-online.com/Forums/ope...striction.html
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 7, 2014, 07:27
Philipp
It's both the standard k-epsilon without any addition.
Old   January 7, 2014, 08:26
-mAx-'s Avatar
Maxime Perelli
As far as I know there is no "enhanced wall treatment" option in OF like in Fluent for standard k-epsilon turbulence model.
But you can use k-Omega SST model with nutUSpaldingWallFunction.
Then set k and omega with uniform value 1e-10 instead of zeroGradient, especially if you have low y+ (y+<=1)
Old   January 7, 2014, 08:30
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
I can confirm your results in fluent. Is the "standard" k-epsilon model exactly the same in both solvers, i.e. are the same values used for the coefficients?
Messing with the coefficients in fluent, one can approximately reproduce the results from OpenFoam
flotus1 is offline   Reply With Quote
Old   January 7, 2014, 08:34
Philipp
Hi, I think the coefficients are the same for the standard k-epsilon. Most likely the boundary conditions are different, also I can't find exactly what Fluent does with all different turbulence values at the walls.
Old   January 7, 2014, 08:37
Philipp
Max, I also wrote in the thread you linked: I don't understand why you would set omega to zero for y+<=1 case. It should be some very high value instead.
Old   January 7, 2014, 08:46
Philipp
K-Omega-SST comparison:
Old   January 7, 2014, 09:21
-mAx-'s Avatar
Maxime Perelli
Thanks for correcting me.
Old   January 8, 2014, 07:05
Philipp
Old   January 10, 2014, 01:38
Default Standard k-epsilon model
  #11
Geon-Hong Kim
Geon-Hong is on a distinguished road
Although you applied low Re BC on the wall, the standard k-epsilon model can not resolve appropriate turbulent field near the wall since it does not include a damping function.
Setting y+ to be close to the unity near the wall for the "standard" k-epsilon model is quite nonsense and I don't expect the solution to be correct with such settings.
It seems that you are trying to tighten a screw using pliers instead of screwdrivers. You can tighten screw somewhat using the pliers but it will not be tight enough.
Meanwhile the k-omega sst model can inherently resolve the viscous sub layer, and it is natural to estimate reasonable solution with y+ ~ 1.
If you want to maintain the y+ near the wall and use a k-epsilon family model, I'd recommend you to apply low Re k-epsilon model with low Re BC's, such as Launder-Sharma k-epsilon model.
Geon-Hong is offline   Reply With Quote
Old   January 10, 2014, 01:45
Philipp
Hey Geon-Hong. Great! Thank you for the answer. That sounds pretty logical. I thought that maybe the wall function will patch all near boundary cells to apply the damping. But I didn't have a look at the source code, which should have revealed what you wrote... Thanks again!
AshwaniAssam likes this.
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 21:25
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 06:12
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 11, 2012 23:18
Can OpenFOAM generate flow at the speed of light? Michel_sharp OpenFOAM 6 October 24, 2009 04:09
flow in perforated pipe distributor pertupd ANSYS 0 August 12, 2009 08:36
