Fortran write help
Old   January 25, 2007, 11:30
Default Fortran write help
Praveen. C
I want to write a set of numbers on the same line.
write(*,*)(x(i),i=1,n)
works fine. But I want to control the format.
write(*,'(e20.10)')(x(i),i=1,n)
puts each number on a new line. Since n is variable I cannot hard code it into the format. Is there any way to achieve this in fortran 77 ?
Old   January 25, 2007, 13:15
Default Re: Fortran write help
Renato.
try it:
write(*,999)(x(i),i=1,n) 999 format(e20.10,/)
Regards
Renato.
Old   January 26, 2007, 00:20
Markus Lummer
Hello Praveen,
you could buildup the appropriate format string in a character variable.
Regards, Markus
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Fortran Compiler-CFX12.1 Araz CFX 13 March 27, 2017 05:37
how to write user fortran for turbulence model waynezw0618 CFX 2 July 10, 2009 01:55
Fortran Compilers to write routines in CFX Luiz CFX 1 February 11, 2008 13:02
visual fortran Monica Main CFD Forum 1 August 28, 2004 20:45
