Why is there residual in any iteration !??
Old   January 29, 2007, 05:42
Default Why is there residual in any iteration !??
Asghari
Hi all;
We know in any iteration discretized form of any equation is: Ap*Phi_p=An*Phi_n+As*Phi_s+Aw*Phi_w+Ae*Phi_e+Sp (a)
On the other hand, Residual is defined as follows:
R=Ap*Phi_p-(An*Phi_n+As*Phi_s+Aw*Phi_w+Ae*Phi_e+Sp) (b)
therefor,with due attention to discretized form (a), Why is there residual in any iteration?
Thanks in advance for everybody help me in finding of an answer to this question.
Old   February 6, 2007, 05:31
Default Re: Why is there residual in any iteration !??
George
You sove equation (a) for every node (i,j,k). For the first (i,j,k) the residual R=0. But in every equation each node depends on the neighborhood nodes and also the coefficients depend on the velocities etc. Also every equation (3 momentums, continuity, energy and so on) depend on the other variables. So at the end of the first iteration no equation will have converged. Too bad that the problem is coupled...otherwise one iteration (or two) would be enough
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
